20 Most Recent Spark Plugs BR4HS Plug 10/BX #3322 Questions & Answers
the rc-se76 is the HT leads not a plug.
if it was a plug then no it would be colder as the higher the number the colder it is.
Spark Plugs... | Answered on Jun 30, 2019
I believe its .44, Check on the Serpentine Belt routing diagram under the hood should be stamped there..
Year? Engine code? 8th digit on Vin #.. Will help also
Good Luck!
Spark Plugs... | Answered on May 22, 2019
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Spark Plugs... | Answered on Jan 29, 2019
Spark plug gap size for 02 toyota echo?
NGK BKR5EY Spark Plug Gap: .031 inches or .8mm
Spark Plugs... | Answered on Dec 07, 2016
Even my kia spectra has 100 ,000 mile plugs, But I change them every 30 to 40 thousand miles to be safe and the engine runs better. God-Bless! If changing the plugs, put in reccomended ones for your vehicle the originals.
Spark Plugs... | Answered on May 11, 2016
An auto parts store will tell you! advanced auto, autozone etc,
Gap should be 0.80mm
Spark Plugs... | Answered on Mar 02, 2016
Here you go....
Spark Plugs... | Answered on Jul 16, 2015
You people need to start giving more info pertaing to your question.
In this case engine size would help. Any their are 3 engines for this vehicle. two of them Are L4 153 2.5 Liter, one is non turbo the other is a Turbo,the Spark Plug gap for both of these engines is .035in
The 3rd engine is a V/6 & the gap for this one is .039in to .044in
Hope this helps
Spark Plugs... | Answered on Jun 01, 2015
It is not receiving a spark, replace the plugs with new ones.
Spark Plugs... | Answered on Apr 08, 2015
The plugs should be set already from the factory. If not they should be set at 1.1mm
Spark Plugs... | Answered on Mar 10, 2015
0.3 , 0.8mm gap required in spark plug. and heat the plug
Spark Plugs... | Answered on Mar 05, 2015
If it's an 8 valve engine and not the 16 valve:
Bosch Spark plugs have a gap of 0.8mm
NGK spark plugs need a gap of 0.9mm
16 Valve engines have a 0.9mm gap on each type of spark plug.
Best to use the plug from the car manufacturer as tests have shown they perform the best for most cars. Call the dealer and but it from them as they will know. I've tried all the performance plugs and dealer is the best.
Spark Plugs... | Answered on Jan 25, 2015
window motor might need to be replaced or the power connection might have come loose and needs to reconnected. Also the fuse might be blown, but I doubt that as the other windows must work.
Spark Plugs... | Answered on Dec 08, 2014
Hello, do you have an 8 cylinder engine?
if so, count from the right side of engine while you are facing from the front. Spark plug wires going to plug, it's #1, #2, #3, #4 then look to the left of you and count #5, #6, '#7' and the next one would be #8.
Spark Plugs... | Answered on Nov 09, 2014
You will have to replace the wire. Pull old one off remove spark plug pry the metal end of the wire off the spark plug. Replace spark plug install new wire. there is anti stick for spark plug wiring I would use if I was you
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
360 questions posted
Top Ngk Vehicle Parts & Accessories Experts
Greg Bernett
Greg Bernett
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Ngk Vehicle Parts & Accessories
Most Popular Question
ngk equivalent spark plug denso w16exr u
  • Vehicle Parts & Accessories
