Hi guys,
Have you tried to format drive? try to do slow format on the FAT32, and when you put the drive into camcorder should work fine. Also make sure if you have got just one partition isntead of for example 2 or more.
I got the same HDD error on mine also. I removed the zif drive from the camcorder and checked it with an external zif hd adapter and the hard drive was good. I emailed JVC and asked them what is wrong with it they said to just mail it in for repair. I think it has to do with deleting the original hidden files and folders that were factory installed because when I checked the hard drive for folders it didn't have any in it(mistakenly deleted or moved). From what I have read from the manual you are not suppose to change folder names or delete hidden files. Hope this post helps you out a little. If you figure any thing else out post more info. Thanks.
how do i fix hdd errors
