Car Audio & Video Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I select the source for usb or dvd on my Legacy LD33M deck it reads "cannot perform function while driving", even when I'm not even driving...can I change this?
Sid
Level 3:
  • Master 483 Answers
  • Posted on Mar 28, 2009
Sid
Master
Level 3:
Answers
483
Questions
Helped
191517
Points
1547
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
Kd-r400 can't recognize usb
You might have to reset the logic by disconnecting the power to the unit. Remove the fuse temporarily, or both fuses if it has 2.
Feb 18, 2014 • JVC KD-R400
I want to be able to listen to music in my car using my USB Sandisk Cruzer but my car only accepts an iPhone plug into an Aux hole. Is there anyway I can by pass this
You might be able to using one of these usb to audio lead you can also get these just as adaptors without the need to for a lead http://www.ebay.com.au/itm/3-5mm-Jack-Plug-to-USB-Male-MP3-Mp4-Audio-Data-Cable-White-/330831058200?pt=AU_Electronics_Portable_Audio_Accessories&hash=item4d07115518 $4.12 3.5mm Jack Plug to USB Male MP3 Mp4 Audio Data Cable White or http://www.ebay.com.au/itm/USB-Male-to-3-5mm-Audio-Stereo-Headphone-Jack-Plug-Cable-For-MP3-MP4-Black-/160733005608?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item256c6f0728 $1.50 free postage You might get these on Ebay im not sure which country you are in this might guide you to one You could get this on Ebay if you dont have an account you will need to create one. https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Music has become more mobile than ever before, as numerous devices can store and play music on-the-go. Companies have developed car audio decks that incorporate USB ports in the faceplate. This allows flash drives to be plugged into the deck, and music on the drive to be played. Flash drive format issues are minimal, considering nearly all flash drives are formatted in the FAT32 file system by default. FAT32 is readable by any operating system, or stereo deck with a USB por
Determine if the stereo deck in the vehicle is capable of playing music off a USB flash drive. Read the stereo deck user's manual, or inspect the deck faceplate for a USB port. Plug a USB flash drive into an available USB port on a computer. Check the drive to make sure there is enough available space for music files. Using Windows, double-click the desktop icon labeled "My Computer." Right-click the flash drive icon, and select "Properties." Capacity will be shown. Using Mac, click the flash drive icon once it appears on the desktop. Click "File" in the top menu bar, then click "Get Info." A dialog box appears, and capacity is listed. Drag and drop any desired music files onto the flash drive. Be sure the files are in .mp3 format. Although some stereo decks are capable of playing other music types, the .mp3 extension is universal and all decks will play it. Spend a short amount of time organizing the files into folders. Organize by genre, artist, or create mixed playlists. Selecting music while driving will become much less distracting. Close the drive window, and safely eject the flash drive from the computer. Plug the flash drive into the stereo deck of the vehicle. Select the USB port as the music source, via the stereo deck. Read the manufacturer's user manual if unsure of how to change the source. Adjust the volume, listen, and enjoy. Hope this helps.
1helpful
My cd player resets everytime i turn my car off and i have to reset the settings. I have the antenna wire connected. What else could be the problem?
First off, where do you have the antenna wire connected to? It sounds like you have the yellow wire connected to a 12v source that turns off when you turn the key off. The yellow wire needs to go to a source that still has 12v when you turn the ignition key off. The yellow wire controls the memory of the deck.
1helpful
2answers
HI. I RECENTLY got a hp proLIANT ML 330 G3 server. It did not come with any OS.. IT had only cd drive.. so i burned SERVER 2003 IN usb and i want to server to boot from usb.. when even i switched it on it...
I am sorry to advise you I have had the exact same issue with a ML330 G3, and it doesnt support USB boot , There are 2 work arounds, 1 is to burn 2003 to a CD as opposed to a DVD and then boot from the standard drive, the other option is to swap out the internal IDE CD Drive to a IDE DVD drive, these are pretty cheap to purchase and easy to fit, the key to fitting is that the ribbon that fits in the back of the drive has a stripe down one side, The side with the Stripe always plugs in nearest to the Power plug that you also plug into the drive.
If this helps, please can you provide positive feedback
Regards
Andy
Can i on usb of this radio a portebel 1T hd working? a usb stick wil work but a hd not is there a solution? gr ray
Unfortunately not, First, Most Many Decks don't offer a powered USB port. Because the Portable HD has Moving Parts It can't start up without a power source. Also Many HD require specifi Drivers in ordered to be Functional, which the Deck most likely does not have installed on it... and unfortunately I don't brelieve there is a way to do intall them. One Solution you could try is to buy a external drive that has a seperate power source from than the usb and then try plugging it into an inverter and connecting it to the deck via the usb. I can't garuntee it'll and i believe you may just be better off purchasing a large capacity flash drive. Hope this helped
4helpful
2answers
Starting today my drive is being read as a cd-rom only, i cant burn a dvd. wont even read a disk (i have cleaned the lens).
This in indicative of a dying drive.
I have no idea why but external drives do seem more prone to it.
Additionally if you have recently added any new burning software you may want to un-install it as I have seen that too fix similar issues.
May I suggest you connect it to a different computer first to eliminate your own computer as a suspect.
Make sure you use the leads that came with the drive and not one that just happens to fit as some leads are not always compatible even though they may look the same.
If it is still under warranty you may want to investigate that option.
Hope this gives you enough to get you sorted out as to what to do next.
Bob
1helpful
Dell Latitude C510/c610 Can this notebook book from the USB Port? I want to install Fedora Linux on my newly repartitioned HD but I can't read the DVD (don't have DVD drive available).
When you want to boot to the USB hard drive just have the drive installed, reboot the system, select the appropriate function key to go to boot options (should tell you what to press in the beginning of boot up) and select USB hard disk.
An important thing to note: Most Linux distributions won't boot from a USB hard drive or thumb drive without a special program for unpacking it to the USB Hard disk. Check with the distribution website for special instructions.
Good Luck,
NOLA Tech
2answers
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
3helpful
2answers
Deh-p6000ub usb mass storage device issues
Pioneer head units (decks) have a function wherein u can opt for AUX -ON / OFF.Similarly USB -ON /OFF.Why is this function given,i dont know.
To choose AUX "ON" or USB "ON" put the power OFF from the SRC SWITCH,PRESS THE MULTICONTROL ROTARY KNOB for 1-2 seconds .the display will show AUX OFF or USB OFF.Select "ON"on pressing the multicontrol knob again.
Now connect your device via the AUX or USB jack and see
i hope your problem is solved.
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Top Legacy Audio Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
