20 Most Recent
ASUS SDRW-08D1S-U USB 2.0 Slim External DVDRW with Cyberlink Software - White Burner Questions & Answers
The device will eject the
Mechanical issue - check the drive that powers the tray ejection.. could have bad or stretched belt.
9/12/2017 9:42:47 PM •
ASUS...
Answered
on Sep 12, 2017
Starting today my drive is being read as a cd-rom
This in indicative of a dying drive.
I have no idea why but external drives do seem more prone to it.
Additionally if you have recently added any new burning software you may want to un-install it as I have seen that too fix similar issues.
May I suggest you connect it to a different computer first to eliminate your own computer as a suspect.
Make sure you use the leads that came with the drive and not one that just happens to fit as some leads are not always compatible even though they may look the same.
If it is still under warranty you may want to investigate that option.
Hope this gives you enough to get you sorted out as to what to do next.
Bob
12/16/2011 3:27:33 PM •
ASUS...
Answered
on Dec 16, 2011
The ASUS sdre-08d1s-u is not
I have the exact same unit, and after about 100 burns the little guy gave out on me. If it isn't burning, I would recommend going into your device manager on your computer and checking to see if your USB hub is functioning properly. In that doesn't work, or you don't find any issues, try plugging it into a different machine to check and see if your computer is the one at fault. Often, the motor itself is the damaged unit, rather than the internal workings, so the computer says it's working fine, and lo and behold, the drive won't work. If that doesn't work out for you, then unfortunately it sounds like you're out of luck, and it would be cheaper to just purchase a new one.
7/22/2011 8:28:54 AM •
ASUS...
Answered
on Jul 22, 2011
Where and how can I
try this link below it should get you the driver you need, if all ok please vote for me
2/14/2011 3:00:54 AM •
ASUS...
Answered
on Feb 14, 2011
Can,t read CD
your laptop drive lence is bad please replace it
1/18/2011 1:40:17 AM •
ASUS...
Answered
on Jan 18, 2011
It will not play a
is it recognised there is a disc in? more info on symptoms for more a accurate answer.
12/30/2010 9:11:34 PM •
ASUS...
Answered
on Dec 30, 2010
How do you set the
It should have a quick installation guide, a USB "Y" cable and a disc with Turbo Engine, ASUS Live Firmware Update, and Power2Go on it. The drive does not plug into a wall outlet; rather, it pulls its power from two USB 2.0 ports on your computer. This is a nice feature if you use a laptop.
Typically you would run the software and then after (or sometimes during you will be prompted), the software is installed you just plug it in and the computer should recognize it. Should be pretty easy. If it doesn't work that way simply uninstall the software, plug the unit into you computer and then run the software. If there's no prompt telling you to plug it in during the install then it can only be one of the 2 ways. I would start with the unit unplugged and wait for a prompt or for the disk to finish, if you don't have a guide.
Hope this helps
11/30/2010 1:19:26 AM •
ASUS...
Answered
on Nov 30, 2010
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
3/23/2010 3:45:13 PM •
ASUS...
Answered
on Mar 23, 2010
Won't read disk
This is due to dust in your drive lens. Please clean the lens using lens cleaner CD/DVD.
Revert back for more assistance.
1/18/2010 6:55:04 AM •
ASUS...
Answered
on Jan 18, 2010
