Averatec 3200 Notebook Logo
Anonymous Posted on Jul 02, 2013
Do i have to use wi-fi or can i hook directly to internet?
John A. Crowder
Level 3:
  • Master 470 Answers
  • Posted on Jul 02, 2013
 John A. Crowder
Master
Level 3:
Answers
470
Questions
0
Helped
109704
Points
1411
Depends if you have that capability. R45 cable input the one that looks like a big phone plug if you do not have wireless internet software on your machine. You can also buy what they call dongles. These are USB wireless receivers. Check Amazon.com or go to a local computer store. Also look at the top area to see if there is a radio button that is blue in color or a switch either in front panel. You can do dongle for under $10.00.
You will then be online wireless.
Can I get Netflix on my smart tv I have Shaw direct satellite
Check the Menu and look for Internet Settings or Wi FI settings. You should have a manual that came with the TV so read the section on how to connect with the Wi Fi or Internet. Once you have Internet connection, you should be able to set up Netflix from there.
1helpful
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
1helpful
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Dynex blu-ray wi-fi disconnects after 1 hour
The issue is with the chip that works with the wi fi. It is erratic in operation. Too expensive to fix. Can you just hook it up via ethernet cable for internet connection?
NO ACCESS TO WI-FI
u can also check power setting, it might be on "power save mode"
I got wifi connection in several places, but why, when I turn off the 3G connection from the cellphone provider, I cannot use the internet connection I got from wifi. What do I need to change in the...
These days each WI FI connection has a password which you have to feed to gwt connected to that particular WI FI connection. So please get the password if you want to get hooked to a particular WI FI. You cannot get connected to any Wi Fi.
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
Ps3 won't hook up to fair field suites wi fi
The ports for connecting the PS3 onto the internet might be blocked. Double check with the staff and see if they can help.
Top Averatec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
