Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Posted on Mar 26, 2009
"TX function was not completed" on my MP730
Some days i want to throw this all-in-one out of the window. I try to send a fax, and i keep getting the same error message, "TX function was not completed" Nothing changes from day to day when this occurs. I've tried adjusting the TX start speed to all different levels, and nothing seems to work. When I CAN send a fax, there are NO problems, but on a day I can't, i can try to re-send it 20 times and it keeps saying the same thing, i've tried re-setting the machine, I don't know what else to do!
A
Anonymous
Probably some interference on your phone line...try a line filter.
There is no multi function suite in windows 8
I don't have proper idea..but you can try these steps:
1. Click the Start button Picture of the Start button, click All Programs, and then click Windows Fax and Scan.
2. On the toolbar, click New Fax. If it's the first time you're sending a fax, you'll be prompted to complete the Fax Setup wizard.
3.When you're finished creating your fax, click Send.
If need any help on windows 8(fix windows 8 solution) then you can get technical help from here:http://www.vtechsquad.com/
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Does the Canon 3235i have a time stamp function for sending faxes?
Press> Additional functions > Communication Settings>TX fax settings
3answers
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
L220 Cannon Fax tx function was not completed
It's possible you're not dialing the country's calling code or not dialing the correct sequence for international calling. To place a call out of the U.S. dial: "011 - country code - city code - number" The country code for Poland is 48. The link below contains the city codes for Poland which you may not have. Best of luck and I hope this solves your problem. Thank you for using Fixya and please remember to return to rate this answer.
International Calling Codes
I have a Canon MP730 MultiPass. I have always been able to fax, until recently. I noticed my inability to fax after switching my service from Verizon to Comcast, although I am not saying this is the...
If your Comcast service is DSL, you may need a DSL adapter to work with older analog telephone devices, like your fax machine. You should be able to find them readily available at $10-$15.
2answers
"TX Function Not Completed"
Open up the document feeder and check to make sure no switches are trapped down.
Unable to fax full document
These units usually scan to memory then memory to phone, if there is a lot of items in memory then you may have to clear the memory, and try again, if this is a first, then the machine may not have enough Fax memory to complete the task. consult your manual, you can either add memory or switch the machine to fax directly on these jobs, this is slower than using memory but should get the job done.
hope this is of some help.
Ed
The screen keeps on showing " memory full".
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
1helpful
2answers
OUTGOING FAX ERROR CODE: NG
To do this:
and MEMORY TX: ON?
Hope this helps :)
Chris (ziraffa)
old marine
old marine
ZJ Limited
ZJ Limited
