How do you change the belt?
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
SOURCE: belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
SOURCE: How do I change the belt on Eureka Altima 12 v
Here is
a link to the owners manual which has instructions and a link to the
belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
http://www.eureka.com/FileLibrary/a88c10...
