I was watching the TV when suddenly both vertical and horizontal hols were simultaneously lost. The sound is fine. View video clip of problem here, then tell me what you think. http://youtu.be/bHlRCTcHWRo Thanks. [email protected]
It sounds that the synchronization separator section is faulty. In all modern sets, the section will be a circuit part inside the main IC. Therefore, check out, and replace that IC.
Testimonial: "I'm not familiar with that term. I just acquired an actual service manual, so I'll look for it in there. Or maybe you are referring to the LA7841 Vertical Deflection Output IC? Mine had some bad solder. Too bad fixing the connections didn't solve the problem."
SOURCE: Sanyo 25" Standard Tube Vertical Deflection Problem
you can proceed as follow to fix it. now your problem how to find out whether drive is there or not it is very simple even you donot have scope. you simply touch with screw driver or meter prob at the poibt where vertical signal is input to vertical stage if h/line is spreadindg or tries to spread then your output is ok &problem is in drive ckt. for schematic try given site give model no &download it http://www.eserviceinfo.com/index.php?what=search2 hope this will help
SOURCE: users control manual adjustment
there are little plastic knobs on the inside or its done through the service menu. try http://www.shopjimmy.com/ they have really good on site techs that will help you on the phone for free.
Check out the solder joints on the LA7841 Vertical Deflection IC;
Add a Commenthttp://www.flickr.com/photos/kfhaggerty/9155805794/
Fixing the solder joints had no effect. Any help out there?
