I tried to use jb weld to reattach the magnets. I had fire but tiller only backfires when trying to start it. Imust have got the timming a little off.is there anywaytoget the magnets in the right position.thanks for any help you can give
Hello, my name is Mark
Sorry to say but the only way to fix it is to replace the flywheel. After you put the new flywheel on you will have to double check the gap between the flywheel and the coil if you take a business card it should just fit between and should be a little snug. If the coil is off a little you will have problems starting. You can adjust the gap by loosening the 2 bolts on top of the coil lust enough that you can tap the coil towards the flywheel, just before you loosen the bolts turn the flywheel so the magnets on the flywheel are not where the coil sits but just to one side or the other of the coil, then set the gap, tighten the bolts and turn the magnets are where the coil is with the business card in between. It should be fairly snug to where you can just get the card out and not tear it in any way. Put your cover on and check for spark and you should be ok. Any questions please feel free to ask. Good luck and have a nice day.
mark thank you for taking the time to answer my question. I had the feeling that the only solution was a new flywheel but always hoped for another fix
