20 Most Recent Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Questions & Answers
dirty carb will do this easily.
Troy Bilt,... | Answered on Feb 07, 2018
i doubt it to be sure replace vthe rubber bushing that is what the problem is i think.
Troy Bilt,... | Answered on Oct 03, 2017
Hi Jesse:
SPARK PLUG AIR GAP ON ALL MODELS IS
.030 (.762MM)
NOTE:
Not all spark plugs have the same heat range or reach. Using an incorrect spark plug can cause severe engine damage or poor performance. Tecumseh uses all three of the reaches shown.
Ta Da!
Troy Bilt,... | Answered on Mar 13, 2016
well it's a list of recalls
Troy Bilt,... | Answered on Aug 30, 2014
-Possibly fuel line is clogged between tank to carburetor. Or the line
is closed. (Most tiller has a Open/Closed valve that let you open and close the gas line)
Good luck
Mai
Troy Bilt,... | Answered on Aug 29, 2014
-Adjust the engine forward a little until it's good.
Good luck
Mai
You can get this manual directly from the troybilt.com website. A lot of manufacturers have their manuals available and just out of curiosity I checked there and in they do have tillers like the one pictured here. Enter pony tiller in the search box and you'll get a page of their different models. Click the one you have and it opens into another window showing the tiller, and beneath it is a bar with "overview" Specs" "Accessories" and "Parts & Manual" You can download the manual and - "yippee!!" - it's even free.
Troy Bilt,... | Answered on May 18, 2014
Check the fuel. Pour some fuel into a clear jar and let it set. See if it seperates due to water in the fuel. Very common problem.
Rich
Troy Bilt,... | Answered on Nov 08, 2013
Check for another sheared shear pin.
Troy Bilt,... | Answered on May 23, 2013
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Troy Bilt,... | Answered on Sep 07, 2012
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
139 questions posted
Top Troy Garden Experts
Neil Hancock
lnbn1975
Dave
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
old troy bilt tiller spark plug gap
  • Garden
