The blender blade is not turning in the blender glass. the small rotating piece on the base that turns the blade seems to be not connected tightly to the spinning part of the motor. therefore, when the small rotating piece connects with the base, there is not enough friction to turn the blade.
This is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Anything that is made can be easily reproduced. Silicone molding compounds are readily available at alumlite.com as well as many grades of polyurethanes.
Once the mold is made it costs only a few cents of polymer to make a part, and often its superior to the original part.
The only tools you need are dixiecups and a scale.
If you plan to sell the parts, do not make a mold of the original part as this may be copyright infringement.
Obsolete parts are usually Free range if the patents have expired, but you may not be able to find out.
But it is legal to make a prototype that "is similar" to their part and may even be a improved model.
When selling be sure to list the part as NON-OEM and "FOR" that make or model of machine.
When I try to make milkshakes the blender blends for a couple of seconds and then stops turning. I replaced the rotating teeth and it still does not work right. I can hear the motor whirling but it doesn't connect. I wait a few seconds and try again. It is like the icecream is to thick for the blades to turn.
fill and add blades turn to put on base and leaks all over no matter how tight
my blender blade is not rotating . i would like to ralace the coupling i do0not know
