if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
It sounds like the temperature sensor has malfunctioned. When the sensor reaches a certain temperature it opens the contact to the heating elements shutting off the toaster. If the unit is under warranty then take it to a repair facility for Krups. I would not allow anyone to use the toaster. If left on it could cause a fire. Take care, stay safe and good luck with your unit!
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
I do not know the exact inner workings of this toaster, but I can suggest what the fault may be.
Many of the toasters use a separate high power section in the eating element for toasting. This part of the element could have gone defective. There is the possibility the computer board that directs the power for the higher temperature mode for toasting has failed.
The only reliable way to know is to try the computer board, element assembly, or the switches if the switches are on a separate module than the computer board.
Just to add... These toaster units usually have a thermo protection fuse. These fuses have a temperature rating. It would be in series with the element. This fuse may have failed. This is a common fault in many of these types of units. This type of fuse is rated in Degrees C or F, and not in Amps. it is a thermo fuse.
No promises, but I had a similar problem with a Breville Clasic. Toasters these days use a solenoid (electromagnet) to hold down the toast carriage. This solenoid is usually soldered to the circuit board, and is reasonably big, i.e. 1/3 a cigarette pack.. on mine, because of repeated impact when the carriage is pushed down, one solder connection developed a haiirline fracture. This meant that most of the time it wouldn't stay down. I resoldered the connections and all ok.
returned it to vendor and asked for exchange. decided no way I should fix it after less than 5 days of use. Curious if others have encountered a similar problem.
the release mechanism contains a bimetallic strip that snaps open when a certain amount of power goes through it based on the setting. When cold, it should trap the toast loading lever mechanism. If not, it may be broken or bent. Don't work on it with power applied
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
