20 Most Recent
Krups FDK2 Waffle Maker Questions & Answers
Krups Blender 577 replacement of rubber coupling
Krups Blender 577 - first try it not easy but next time it will be.
Replacing the rubber coubling is extremely difficult with this model.
After almost destroying the air in/outtake grill on the side in pursuit of a good lock of the axe, I tried so hard to use a nose plier to grab the post and unscrew the coupling counter-clockwise but it just didn't fit (it needs to be long and narrow/needle like). So I ended up cutting off rubber on the coupling and also cutting of plastic from the black plastic cover which is just under the rubber coupling. In the end I was able to cut that plastic and remove it so that I could actually take off the whole casing (you need a torx 20 with a hole in it to unsrew the 4 bits at the bottom underneath the rubber stands) with the rubber coupling still attached and detach two power cables so that I had much more space to properly grab the post and then it was very very easy to unscrew it counter-clockwise. But up until then I lost my insanity twice :-).
Now I know how to so the next time will be easier.
I just bought a rice cooker at a garage sale. It had no instruction manual
To make rice, remove the trivet if you have one as this is only for steaming food.
Wash rice to get rid of excess starch and put in pan. Then add the same amount of water as rice (2 cups water to 2 cups rice etc.) then shut lid and switch on and leave it.
Once it has switched off do not open the lid for a further 20 minutes (the machine will keep the rice warm do not worry) Stir rice and serve. Most rice cookers will keep the rice warm for a couple of hours.
If you find the rice is a bit dry then add a little bit more water, the amount of water really depends on the quality of rice used.
