Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta Bizhub C353 fails scan to emails
We just had a Bizhub C353 installed last week and the tech has not been able to get the scan to email service to work. They copied the settings from an old printer with works but the Bizhub doesn't work it fails Authorization.
  • Anonymous Mar 18, 2014
    bizhub c353 login error
Anonymous
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on May 26, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
62
Questions
0
Helped
83146
Points
160
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
  • Anonymous Dec 06, 2012
    Would you be able to help me? I have this c353 at my work. All computers are connected to a server group, windows firewall disabled, but i have ESET, I have connected the c353 via TCP/IP information on my c353, I can ping the IP address successfully, I just cannot scan via SMP, I am terribly confused and have tried solutoion after solution, please let me know if you have anything? Thank you
Memory full
add additional memory, contact local KMBS dealer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
I have to Konica Minolta printers one a BizHub C220 & the other BizHub C353. All the scan to email function except for to users that have a large email account. I did setup an alias and forward the...
Hi Tim,
Can you please let me know the exact error message that you get , while you attempt to use the scan to email function?
May end users believe to scan-to-email to themselves internally, and then send it externally.
and the find it as a probably better option, as we get to preview the attachment before it goes out.
If you are using an exchange server then the exchange cannot handle the message size or attachment size, as well as when there is actually not enough space on the server probably it's full or near full.
Try setting up the email account again and then check if the problem persists, most probably this problem would not persist after a reset of the email account.
Hope this helps...:)
1helpful
Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
1helpful
3answers
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
1helpful
Adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
