My 76 Transporter ran last summer and fall. It was garaged over the winter. The battery was completely dead, so I replaced it this morning. It turns over, but it won't start. Any thoughts?
SOURCE: crank, no start 98 wrangler 2.5l
crank sensor likely-may be distributor sensor but my 98 sport was crank sensor situated in bell housing timed by flywheel
SOURCE: ford f150, 2004 ford 4x4, 4.6l - kills battery, turns over but wo
You need to find the current drain. Charge the battery, then disconnect the Negative terminal. Now connect a 12v tester or a automotive lamp between the terminal and the battery post. This will put the tester/lamp in series with the current flow and they will light if there is any current drain. So assumming the light is on, now pull fuses one at a time until the light goes out. Remember to keep the door light switch from being activated as that will cause it's own current flow. Do not turn on the ingition since the failure happened over night while the truck was off and closed. There will be a normal very small current flow all the time to power the radio preset memory and perhaps an alarm but that flow will barely light the lamp. If the lamp is blown due to a real high current flow then you will neet an ammeter with about a 50 amp current rating.
SOURCE: 98 ford contour won't start and when I stop
You likely need a new starter. The whining is the starter motor slipping.
Hope this was helpful.
SOURCE: 2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
SOURCE: Car won't start, battery is good, won't even turn over.
These vehicles are prone to failures in the antitheft system. This will actually lock out the starter and/or injectors. Read thru this link, might be your problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
