I installed two harbor breeze fans in a friends living room. All worked fine for about 8 months. Last week all the lights went out on one of the fans. So far, I replaced the pull chain for the lights because the switch was hanging up. Light still won't work. I check power on the leads that the ligh kit plugs in to. I have 120 VAC across the two connections. I tried the light kit from the bad fanon the good fan and the lights worked. I tried the lights from the good fan on the bad fan and those lights didn't work either. Any suggestions?
Did you check for corrosion inside of the light sockets?
I see you replaced the pullchains too, that is a good step.
I found this article that has some really good step by steps on how to diagnose this problem, as well as images and videos that should help you through this problem
https://yourceilingfan.com/harbor-breeze-troubleshooting/light-kit-not-working/
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
SOURCE: i am installing a harbor breeze ceiling fan i
Please try this link below because this might help you. You will see lots of link from the site just select the better solution that can give you.
Just click HERE so that you will be directed to the site:
Thanks
