Exterior for Ford Focus (3 Door) Hatchback Logo
James Posted on May 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a parts breakdown of the right side door handle, something is broken and I can't open the door from the outside
Bill Boyd
Level 3:
Top Expert:
  • Ford Master 53,816 Answers
  • Posted on Aug 05, 2013
Bill Boyd
Ford Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951325
Points
172802
IT will be difficult to get a parts break down of what you want so I suggest two things . Go to a wreckers and look at a door lock the same as yours or go to the dealer spares and have a look at their break down to see what would have broken. Most spares people are willing to help correctly identify the parts for you.
2helpful
2answers
How do i replace offside rear door handle
You would need to take the pannel off to get to the internal part of the mechanism. Something has broken or come apart in the opening mechanism. I'd let it go if considering replacing.
2001 focus door handle
if you can identify broken part go to auto store or dealership they can show you schematics .
May 31, 2013 • Saws
Drivers door won't open from outside
remove door panel,peel back water barrier on top left side,remove 10mm bolt on back of door handle,in top of door jam remove 10mm bolt and Phillips screw right below bolt,carefully pull out door handle and remove rod from it,contact Volu parts in Atlanta Ga at 1-888-280-4057 and order white plastic pivot arm,they will know what you need. remove metal drift pin from handle by squeezing with pliers lightly!!! and pulling remember most handle parts are plastic and old be careful. the only door handle new is OEM and over 100.00 and you have to paint to match car.
2answers
1997 Toyota Rav4 driver side interior door handle broken
Parts can be had from a junk yard...remove door panel and push up on the connecting rod to open...generally, a little piece of plastic slips off or breaks inside the door. It is attached to a certain part of the rod. Should be white or clear plastic...look for the broken bits when door panel is removed so you know what you need....cheers
1helpful
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Outer door handle does not open door on drivers side how do I fix it? Inner door handle works.
There are one of 2 things wrong here. Either the outside handle is broken, and you'll need another one, or it is out of adjustment and can be repaired. It's a little work to find out either way, the inside door panel must be removed. This is lots of screws, you'll see as you start removing them. The black triangle plastic near the rear view must be taken off, pry the little round plug out and then remove the nut. Finally the panel lifts up, give the bottom a smack upward with your hand, it WILL come up.
Now is the tricky part, you need to see whats wrong. There is a rod connecting the door handle to the door release. If the rod looks like it moves up and down when you move the outside door handle up and down then it needs adjusting.
See the picture of the door handle...the white nylon clip on the right must be separated from where it attaches to the rod, then the rod is positioned higher so the handle can pull it up enough to open the door.
If the rod does NOT move when you move the handle, either the rod is completely loose, or the handle is broken. Remove 2 nuts from the inside and the handle comes out, and put back in a junk yard or ebay replacement. Good luck...Chris
The front passenger door will not open with the outside door handle or the interior door handle. after taking the inside door cover off, i discovered the interior door handle is broken and the connector...
The locking mechanism is manufactured with carbon composite and plastic levers that the door handles attach to. It is hard to tell what parts that you do need. Remove the passenger side door panel. It will have some screws and maybe a bolt on the inside handle. The panel has snap plug on it and they fit into designated hole in the door. After getting the door panel off, be careful here, there are sharp metal edges that can cut. There are some peep hole to see the rods and connector inside the door. If the plastic hooks on the door locking mechanism are broken. The hole door lock assembly will need to be replaced.
Try your local wrecking yards and tell them what type of vehicle you have and year. Also, state what door it is and what you will need.
Now, if the interior door hand hook on the lock mechanism isn't broke off. The get a cloths hanger and straighten it out and attach it to the opening latch on locking mechanism. This will give you inside temporary handle, while you are trying to fix the door. Safety. GB...stewbison
My rear door on the passenger side is stuck so I can't open it from the outside. but today when I had the door open to ***** the problem my little brother flipped the button and turned on the child lock....
It sounds like the plastic connecting bit that links the outside door lever to the rod, that operates the door mechanism, has broken or become disconnected. To check, you will need to remove the trim on the inside of the door, after removing any screws and the inside door lever. However now that the child safety lock has been set it could be very difficult to get the door open.
All I can suggest is that you look at the other rear door to locate the position of the safety tab and then try to disengage it by using a suitable thin blade or something on your bad door so that you can again use the inside lever.
Once you have the inside trim off and the plastic sheet, you will see an access hole for the door mechanism and the outside operating handle of the door. It should be attached to the actuating rod by the aforementioned plastic bit. If plastic bit appears OK try re-attaching it or replacing it if broken. If the part of the handle which attaches to the rod is broken, the handle will need replacing.
1helpful
2000 Subaru Forester drivers side outside door handle has jammed
take off inside door panel and check the linkage on the lock may be broken
4helpful
3answers
Inside door handle 2004 sebring won't work
First off, you'll need to be able to remove the door panel. there are plastic clips (Push in body clips) as well as a couple of screws that hold the panel on. If you do not have power windows, you'll need a tool available from most any parts store to remove the window crank handle. You can get a window crank handle off with a couple of standard screwdrivers (There is a small metal clip that locks the handle on) but this normally results in damage to the panel. When the panel swings freely away from the bottom of the door, gently slide it directly up to remove it.
Once there, you should be able to clearly see the handle assembly, look for a metal rod about 1/4 inch in diameter that is supposed to be attached to the handle assembly via a little plastic clip. if either the clip or the handle assembly is broken, the rod will disconnect and you will be yanking on a handle attached to essentially nothing.
Door rod clips are available through most auto parts stores for $4-5, handle assembly's you can sometimes get through a wrecking yard, or order from the parts store.
Once you have the panel removed
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
