20 Most Recent Exterior for Ford Focus (3 Door) Hatchback Questions & Answers
Need a parts breakdown of the right side door handle, something is broken and I can't open the door from the outside
IT will be difficult to get a parts break down of what you want so I suggest two things . Go to a wreckers and look at a door lock the same as yours or go to the dealer spares and have a look at their break down to see what would have broken. Most spares people are willing to help correctly identify the parts for you.
8/5/2013 10:38:35 AM • Exterior for... • Answered on Aug 05, 2013
tip
Diesel Pump Rotor Head 1 468 334 337
diesel Pump Rotor Head 1 468 334 337 Item Name(EH)#injector bmw 320d e46# # head rotor ford 12 mm# #head rotor ford 187l# #injector chrysler voyager# #for injector common rail delphi# #Ultrasonic Injector Cleaning Machine #UltraSonic Fuel Injector Cleaning (EH)China Lutong Parts Plant is a famous manufacturer and supplier specializing in diesel engine parts.We have 30 years experience in this area. Our aim and business policy is to give the customer a reliable quality product and service, alternative to the OE products. The parts are quality assured to ISO9001 and are subject to regular internal and external audits ensuring that quality is the highest standard. nicole(at)china-lutong (dot) net Wha/tsa/pp:+86133/8690/1375 nicole(at)china-lutong (dot) net [email protected]
/uploads/images/7123-909t-head-rotor-for-perkins (3)-undefined-undefined-0.jpg
I have a 1996 ford windstar
They remote is for the immobiliser system. Immobilisers are designed to be VERY difficult to bypass otherwise why fit them? Your simplest solution here is to go to a car key specialist and get a new remote. Once the old one fails the car will not start at all.
7/5/2022 6:27:29 PM • Ford Vehicle... • Answered on Jul 05, 2022
Has anyone code for mondeo radio Serial no. V041312
M000281
8/28/2020 4:12:21 PM • Ford Vehicle... • Answered on Aug 28, 2020
3answers
I want to decode my Ford Feista radio ,SAM Model no 14790945. serial number 339486610945
Can anyone help me get the code for my ford focus 2005 model radio code sam model 222599250900 ?i would very much appreciated anyone could help me with this thanks in advance
12/11/2019 10:48:58 AM • Ford Vehicle... • Answered on Dec 11, 2019
2answers
Need radio code for ford bantum bakkie
Search for on google
3/19/2019 4:03:15 AM • Ford Vehicle... • Answered on Mar 19, 2019
Adjust transmission bands
Which transmission? Some bands are not adjustable without getting into the transmission case.
2/19/2019 7:40:29 PM • Ford Vehicle... • Answered on Feb 19, 2019
In Need of a Code to unlock my Radio Please.
A qualified service center can ask a dealership for the code or go directly to the dealer.
2/19/2019 7:39:12 PM • Ford Vehicle... • Answered on Feb 19, 2019
Just replace a Ford Falcon AU radio with a
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u .. U can also get free manuals
1/29/2019 8:27:39 AM • Ford Vehicle... • Answered on Jan 29, 2019
Install bulldog model RS112 into a 2005 Ford Taurus
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
1/25/2019 3:32:42 PM • Ford Vehicle... • Answered on Jan 25, 2019
Im having a problem with my remote start. It goes on , but shuts off in 15 seconds. I have a Ford Explorer with a viper alarm.
Just a guess, since some disengage if signal not getting thru that motor running, to prevent starter brushes overheating, burning, etc, and you say motor starts, maybe a dirty electrical connection, like oil or something got in somewhere, interfering with that signal being received. To rule that out I guess yourself or shop, have all electrical connectors looked at for oil, dirt, oxidation, loose, etc... Simply pulling connectors and pushing back on few times might do it if that the issue. Notice if it feels tight or not. If oily dirty, maybe spray male and female parts of connector with alcohol based spray degreaser. Silicone spray has fast evaporating alcohol but the silicone may interfere with electrical connection. Also, be sure your remote button not triggered by weak spring contacting when you set it down or put in pocket as that'll act to shut off if already on. I had 1 get like that. Would park car, head in, putting remote in pocket after going in, would notice car running from inside.
11/9/2018 2:05:23 AM • Ford Vehicle... • Answered on Nov 09, 2018
Water not curclating around engine
either a stuck closed thermasa or a waterpump
10/21/2018 12:19:46 PM • Ford Vehicle... • Answered on Oct 21, 2018
2008 yukon heat doesn't work in the front but comes on in the back
it could be a couple of things. it could be the main blend door actuator. the other could be a blower motor.
9/21/2017 4:28:58 AM • Ford Vehicle... • Answered on Sep 21, 2017
I have a 2008 Ford Edge with a vital 4103 remote start security system. I start car by remote and my car starts but shuts right back off then it attempts to restart and does the same thing ? Why ?
These aftermarket remote start system are famous for this type of problem, I think it has lost communication with the car's security system, how to fix that I am not aware of.
11/22/2016 9:58:46 PM • Ford Vehicle... • Answered on Nov 22, 2016
2answers
How to program locks to engage when put in gear on 2013 ford exployer?
that is a factory setting on the computer, not user serviceable. talk to ford.
6/6/2016 2:39:01 PM • Ford Vehicle... • Answered on Jun 06, 2016
Where is the fuse for the rear window defroster for a 2003 ford windstar
The fuse panel is below and to the left of the steering wheel by the brake pedal. Remove the cover to access fuse panel. There should be a fuse puller tool fastened to the fuse panel cover. check the fuse in position number 10(it should be a 10 amp fuse). Also check relay number 5 which is the Rear Defrost Relay. If both the fuse and Relay are good, check under the hood for the power distribution box. Locate it, disconnect the battery, open the power distribution box, check fuse number 121 (it should be a 20 amp fuse). Check also fuse number 116(it should be a 30 amp fuse). Replace the faulty one(s) and then close the Power Distribution Box. Reconnect the battery. Hope this helps! Blessings!
3/2/2016 8:06:51 PM • Ford Vehicle... • Answered on Mar 02, 2016
tip
How to remove the rear bumper on a ford ranger 1999
This a short video on how to remove the rear bumper and install a new one on a 1999 ford ranger xlt
Ford 350 super duty 5.4 LT 08 NO CRANK NO STARE
try putting transmission in neutral instead of park , or if clutch equipped try depressing clutch all the way down
1/29/2016 1:45:58 AM • Ford Vehicle... • Answered on Jan 29, 2016
2001 ford ranger how to relearn the computer box
See above.
11/17/2015 3:38:04 AM • Ford Vehicle... • Answered on Nov 17, 2015
Exterior for Ford Focus (3 Door) Hatchback Logo
1 questions posted
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Ford Vehicle Parts & Accessories
Most Popular Question
need parts breakdown right side door
  • Vehicle Parts & Accessories
