I have a ''corded'' phone that came with the curly handset cord permanently connected to the base unit. I want to use this phone as a wall phone for my kitchen. It does not have a modular plug on the base unit so I can't replace the short handset cord with a longer cord. Can I buy a coupler to connect the short handset cord to long cord? Can I cut the handset cord and splice in a female jack so I can add a long curly cord?
(BTW - phone is GE model 29267GE4-B)
(it is REALLY hard to find a good call-waiting/ caller-id wall phone!!!! Most are really crappy. Hard to read displays, buttons stop working, etc. I like this phone but the darn handset cord is too short to be a good wall phone!!!)
You should be able to get an RJ-45 coupler for the cord. It may be a little awkward but should work. Try:
Radio Shack
Frys Electronics
Menards
Best Buy
Your local hardware store
NO! My error! You need an RJ-11 coupler - too much computer work for me!
See the link - http://www.cablesnmor.com/rj11-coupler.a...
for a description. You can probably shop around and find a better price.
Thanks for the catch!
Well, depending on how determined you are, you could get a long pre-manufactured cord, cut one end off, take the set apart, re-solder the longer cord to it and then re-plug the cord. :)
Thanks for the reply!
I believe an RJ-45 coupler is intended for Ethernet cords, right? It is also called an 8P8C connector.
Are you saying the smaller 4P4C plugs will fit in there tightly enough to work?
Thanks again for the reply.
I have a couple RJ-11 couplers. Since
they are designed for standard RJ-11 phone jacks, the female sockets
are wider than the 4P4C jacks. If you snap it in *just right* you get a
dial tone. But as soon as the cord moves around a bit the jack slips in
the socket and connection is lost. I have toyed with jamming something
permanent in to each side of each jack to hold them firmly in place, but I was hoping I would not have to
jury-rig it so much.
So it sounds like you do not know of a solution.
Are there no 4P4C couplers made?
Apparently like this type of connector is often referred to as an RJ22 connector (although Wiki says that is not official).
I found a place that says they have RJ22 couplers:
http://www.trynci.net/product_details.as...
part# 414060E
I guess I have to give it a shot.
