Nautica Blue Dail Yacht Chronograph Watch for Men Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instructions to reset sub dials on Nautica Chronograph watch
I need to zero the sub dials
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    Make, model, all the writings on caseback?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 22, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814238
Points
13579
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
  • darkie1927 Sep 30, 2010
    Helped me sort my Chronotech as well!
Instruction for accutime xoxo watch
This watch appears to be a battery operated model from the details I can find. Self Winding watches tend to be a LOT more expensive and usually a Big brand name! Assuming the Chronograph is designed to work the two buttons are usually 'Start/Stop', (top button) and 'Reset', (bottom button). Try this.
-Press the top button once. The smaller dials should start moving.
-Press the top button again. The smaller dials should stop moving.
-Press the bottom button once. The dials should reset to zero. There is another function of the Reset button. You can 'Freeze' the chronograph display for things like lap times.
-Start the chronograph, (Top button once).
-Press the Reset button once, (Bottom button). The dials should stop. The chronograph is still running you have simply paused the display.
-Press the Reset button again. The dials should 'Jump' to the current position the timer is at.
-Press the Top button once to stop the chronograph. *Note* Some of the cheaper watches simply have the dials and buttons for the look of it and don't actually work.
Jan 20, 2022 • The Watches
How do I zero the stopwatch hands on my Nautica A 29504 chronograph watch
try www.watchshop.com/mens-nautica-bfc-chronograph-watch-a29504g-p9...
1helpful
How do I reset emporio armani ar5950 chronograph to zero after replacing the battery.?
pull crown out to second position ,then press bottom button till it goes to zero then push crown back in job done,,if you want to do both dials press and hold bottom button so they rotate faster to zero then press one press at a time...
Reset fossil mens es3380
fossil mens es3380 (assuming chronograph)
If you are talking about resetting the "sub-dials"
ZERO (RESET THE watch timers...
Obviously they are going to the "zero" spot ... or
we wouldn't be talking ... writing (whatever).
((but this is where they must be to start))
Simply pull out the stem to the furthest position and
press & hold the top button... You will see a sub-dial rotating...
release it when it gets close to ZERO and single click it where you want it...
Repeat the process with the OTHER (bottom) button...
Repeat the process...
Push the stem... HALF-WAY HOME and figure out for yourself which button move what hand.
When everything is ZEROED CORRECTLY...
Set the time & date "normally"
Normal the stem ...
and happy TIME - KEEPING...
If all that fails... as Tom Chichester says... "RTFM"
(read the manual... (but where's the fun))...
Carnac the Magnificent
I have an automatic raymond weil parsifal chronograph. The hour chapter (sub dial) wont fully reset. Any suggestions? thank you in advance.
You should be able to re-set the hands by pressing the button which is at the 4 O'clock position.
The instructions for this watch are rather minimal and do not include any other instructions for re-setting the hands if they do not re-set to zero when B is pressed.
If this remains a problem, I suggest you return the watch to your nearest store for "repair". You can find the nearest store by going to http://www.raymond-weil.com/EN/Retailers-Dealers/Retailers.html and filling in your details.
Jan 17, 2011 • Watches
4helpful
2answers
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Nautica Chronograph Watch for Men-Instruction to set time & Date
hello
i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail
[email protected]
tthenks..
2helpful
HOW TO WORK THE SUB DIALS
This is an Architect Chronograph. To start the chronograph press the top start button. To stop it press it again. To reset it press the reset or bottom button. The sub dials are minutes, hours, and seconds.
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 • Watches
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
