SOURCE: new problem with tv and Sony RMT-V202 Remote Control
Samsung makes AVOL you may want to try there codes. Hope this helps.
SOURCE: code for ferguson tv
These are all codes used by Fergies, hope one works for you.
0073 0287 0192 0190 0335 0238 0193 0109 0625
SOURCE: RMT-V501E "Try again later" message
The manual has instructions on page 10-12. Here is the link to get the manual. http://nzr.mvnu.edu/facilities/items/sonydvd-d360pmanual.pdf
SOURCE: How do you set the TV code for the remote:
How to Program the RMT-B107A Remote Control:
Follow these steps to program the remote control to operate a television.
1) Turn on the TV.
2) On the remote control, press and hold the TV I/O button.
3) While holding the TV I/O button, enter the manufacturer's code using the numeric buttons.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
4) Release the TV I/O button.
5) Point the remote control at the TV.
6) Press the TV I/O button to verify operation.
NOTES:
If a new code number is entered, the code number previously entered will be erased.
When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
The operation of a combination deck of any kind is not guaranteed.
Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
