I have posted the Operator Manual at
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
Is this a request for a GP31 Manual? I have posted
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf which is basically the same beast.
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf The GP30/GP31/GP32/GP35 are all similar.
