Keeps turning off and back on was every hour now down to every few minutes no warning lights good picture and sound when working any body had the same problem and found out what it was thanks
after tv repair man said get rid of it, i managed to fix this problem i think its all one big con to get you to by new tv , there was nothing wrong all in the software, to fix try this. 1. Turn off the power to make the SET STAND-BY mode. 2. In order to enter the Service Mode, Press "INFO" → "MENU” → "MUTE" → "POWER" button on the Remote when in menu screen enter options, reset the bulb hour setting, then there is a lower reset that resets the hole tv press this, inportant make sure there are no inputs connected i.e areial scart or anything. and when resetting language/ hour i did not reset the hour.the tv is now working perfect. hope this works for you allafter tv repair man said get rid of it, i managed to fix this problem i think its all one big con to get you to by new tv , there was nothing wrong all in the software, to fix try this. 1. Turn off the power to make the SET STAND-BY mode. 2. In order to enter the Service Mode, Press "INFO" → "MENU” → "MUTE" → "POWER" button on the Remote when in menu screen enter options, reset the bulb hour setting, then there is a lower reset that resets the hole tv press this, inportant make sure there are no inputs connected i.e areial scart or anything. and when resetting language/ hour i did not reset the hour.the tv is now working perfect. hope this works for you all
You can't post conmments that contain an email address.
This is the most common problem for rear projection tvs and it is known
as the color convergence problem.You will need to replace or repair its
ics to solve it.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
