Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need set up disc - Kodak EASYSHARE 5300 All-In-One InkJet Printer
Anonymous
Level 2:
  • Expert 214 Answers
  • Posted on Mar 15, 2009
Anonymous
Expert
Level 2:
Answers
214
Questions
Helped
142414
Points
676
Here's a link. Just choose your operating system from the dropdown box & you can download the drivers & software. If this helps you plz rate this as 'fixa'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=windows_xp&downloadLanguage=en
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
2answers
How can i restore factory settings without password
You can only restore the BIOS settings by selecting F2 on reboot. You need the password to restore operating system settings. Geek squad can break password.
What's your problem?how do i set my old computer to factor settings
you will need to put the windows disc into the cdrom drive, and set the bios so it boots from cdrom first,
if you didnt get a windows disc you should have been asked to make a recovery disc when you first bought the pc, and same procedure with setting bios.
Acer aspire t180 restore to factory settings on start up
You will need to use the recovery discs that came with the computer and boot from the disc and it will give you the option to restore to factory defaults. If you dont have the discs you will need to contact Acer to get a copy.
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
2answers
Hi drifterk back again for another problem i need help with. okay after i reset the Bios to Optimized Defaults i cant seem to boot my windows 7 setup disc from restart it doesnt pick up any disc's in...
For that when you power up the computer press F1 or F2 or "del" then enter in bios.
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
then it boot with that disk.
Let me know if you need further assistance.
Thanks for using FixYa.
1helpful
2answers
I have lost my set up disc and cannot set it up can i get a disc
dude yes u can get disc simple u need to download u r setup by type u r name wat u want to download in google there u can see many websites if u not find any website just reply me i will send u
X-box 360 screen says " to play this disc put in xbox 360 console"
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps:
1- With no discs in the disc tray, go to the System section on the dashboard.
2- Select Console Settings.
3- Select Start Up.
4- Make sure it is set to Disc not dashboard.
If it is set to dashboard, select Disc and try the game again. It should work.
If is already set to disc or you tried setting it to Disc and still not working try the following steps:
1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not.
2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not.
3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive.
4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
2helpful
Reads no disc when there are discs in there
Need not to worry ok, this is because of the lense problem,
To resolve this you need to replace the entire lense set.
2answers
Webcam
needs to set up webcam but got no disc
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
