Sharp Mx-4501n Color Laser - Printer / Copier / Scanner Logo
A
Anonymous Posted on Apr 30, 2013
Selected servers not found - Sharp Mx-4501n Color Laser - Printer / Copier / Scanner
Skelton Business Equipment
Level 2:
Guru:
  • Sharp Expert 106 Answers
  • Posted on Jul 28, 2014
Sharp Expert
Level 2:
Guru:
Answers
106
Questions
0
Helped
64288
Points
221
This is a common error with Sharpdesk and the Network Scanner Tool. Your IP address has probably changed. Here are some instructions on how to resolve this issue and prevent it from happening in the future.
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Unable to send selected list of digital photographs
Please verify that you have entered the server name correctly
How do i configure my jetdirect 170x
What OS are you using? I had a problem getting the print server to work with Windows 8.1. This is what I found to work: Find the IP address for the printer/server by pushing the "test" button on the print server. "Add a printer" in "Devices and Printers" under Control Panel. Select " The printer that I want wasn't listed", then select "Add a printer using TCP/IP address or hostname". Enter the IP address in the next window and carry on.
I hope this helps. If this is not your problem, you'll need to provide more details about what it is that you need from the print server.
2helpful
I can not connect to gprs
first thing , find the correct APN settings from your network provider .
Same here. Now found:
"Select a Modem" should be set for "Cellular Line (GPRS)" or "Cellular Line GPRS/3G"
Now click "Next" to start inputting the operator specific settings.
O2 (note different settings for Contract and PAYG)
Access Point Name (Contract):
Access Point Name (PAYG):
Username (Contract)
Username (PAYG)
Password:
Tap "Advanced" and make sure both tabs have selected "Use Server Assigned IP Address"
Tap "Finish" then Tap "Proxy Settings".
Select "This network connects to the Internet" and " This network connects to a proxy server..."
below is the example
Tap "Advanced" then WAP. Server address is: 193.113.200.195: Port 9201. Tap OK
Tap Socks: Server is 193.113.200.195: Port 1080. Type: Socks 4. Tap OK 4 times to finish.
1helpful
I am tying to set up yahoo account on thunderbird. i can send email but not receive.. i have tried changing server settings and port settings
Much more common is a sending issue. Often you have to send through your ISP server, contact them for what that server is, if you have sending issues.
I found directions for Outlook, which should be similar to Thunderbird:
Look closely at requires authentication settings....
Note: You must be a Yahoo! Mail Plus user to read Yahoo! Mail in an email reader program such as Microsoft Outlook. Click here for information about subscribing to Yahoo! Mail Plus.
To read your Yahoo! Mail Plus using Microsoft Outlook 2002 or 2003, follow these steps:
  1. From the Tools menu, select Email Accounts.
  2. Select Add a new email account and click Next.
  3. Select POP3 and click Next.
  4. Enter the following information:
    • User Information
      Your Name: Type your name as you'd like it to appear when you send an email message.
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example, [email protected]).
    • Server Information
      Incoming mail server (POP3): Type plus.pop.mail.yahoo.com.
      Outgoing mail server (SMTP): Type plus.smtp.mail.yahoo.com.
    • Login Information
      User Name: Type your Yahoo! ID (your email address without the "@yahoo.com").
      Password: Type your Yahoo! password.
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  5. Click More Settings. The Internet E-mail Settings dialog box appears.
  6. Select the Outgoing Server tab:
    • Select the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  7. Click the Advanced tab:
    • Under Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field usually changes automatically from 110 to 995. If it doesn't, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server once Outlook has downloaded them onto your computer, leave the box unchecked.
      Note: After your messages are deleted from the server, we cannot retrieve them.
  8. Click OK to close the Internet E-mail Settings dialog box.
  9. Click Finish to close the Add New E-mail Account dialog box.
  10. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can't send Yahoo! Mail from Outlook, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!'s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Select your Yahoo! Mail Plus account and click Properties. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click Apply, and then click OK to close the Internet E-mail Settings dialog box.
  7. Click Close to close the Account Settings dialog box.
Oct 17, 2010 • Yahoo Mail
1helpful
2answers
How i can unblocked the facebook?
Try to visit through proxy server, u can find a lots of free proxy server at http://www.proxy4free.com/, select any proxy server from the list. When the page open up there will be a space to enter the url, enter the url and visit any sites.
1helpful
MX-2300 scanner errror message: Selected Servers
You probably have incorrect log in details (Username & password)
4helpful
2answers
When I try to scan to my e-mail I get this message: "Selected servers are not found. Consult your network administrator." What do I do?
In order to scan you need your smtp server adress and dns server address.You also need a valid e-mail address.In command prompt type ipconfig /all and find the details there
My server HDD broke down so seagate send a replacement. now, i was able to set up the OS but can not find the chipset drivers for the model. (video, audio, especially LAN adapter). Could anyone pls he
1. Go to: http://support.asus.com/download/download.aspx?SLanguage=en-us
2. In the "General Download" section, make the following selections:
Select Product == Server
Select Series == 5U/Tower
Select Models == AP1720-E1
3. Click the "Search" button.
4. Select your operating system, & click the "Search" button.
5. Browse the list of files found, & download the drivers.
I can't get outgoing e-mails to leave my Out Box and go into my Sent Mail. [I have MS Outlook and Verizon.] I clicked the yellow triangle in the lower right hand corner of my desktop. "The server could not...
It seems like your SMTP server is missing...
Follow these instructions:
1. Open Outlook.
2. From the Tools menu, select Accounts.
3. Select View or change existing email accounts, then select Next.
4. Select the Verizon account in the Name window, then select Change.
5. Fill in your Internet email settings:
* Type outgoing.verizon.net in the Outgoing mail (SMTP) field.
* In the User name field, type your Verizon Online user name.
* In the Password field, type your password.
6. Select More Settings.
7. From the Outgoing Server tab, check the box: My outgoing server (SMTP) requires authentication.
8. Select Use same settings as my incoming mail.
9. Select OK, then select Next. Click Finish to close the
window.
That should fix it.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
