Canon ZR100 Mini DV Digital Camcorder Logo
andrew armstrong Posted on Aug 06, 2007
Cannon MD101 Wont eject Tape /No Power
Hi My Cannon DV Camcorder MD101 was playing back a DV Tape when it suddenly made the screen slowly turn white and shut down - Now the Camcodrer wont power up even on mains adapter and wont eject the DV Tape - can i manually eject the tape and if so how? Thanks
A
Anonymous
A
Anonymous
Drivere canon md110
Gray Stripes displayed when playing video
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Camera won't playback or record poss damaged heads
I think your problem is in the analog to digital converters. They seem to not be working, It is probably cheaper to buy a new camera rather than fixing yours.
Canon MV850i DV camcorder
Exactly the same problem! Screen going white then no power.
2answers
Canon zr100 died: no power
If you have had the camera for a long time, it may have simply died. This may not help, but you could leave the camera on untill the battery loses all power, then try to turn it back on, and see if it works.
2answers
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Blank screen during playback
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
Cleaning the camera
hi, just insert a brand new dv tape and let it record for 10 min.. rewind back to 5 min and start playing and do a repeated ff and rw you can see the black lines slowly going off.. all the best my friend sreejith
Wont Take Tape
BAD TAPE TRANSPORT. NEED TO SEND IN FOR REPAIR
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
