Shutter opens closes rapidly, Error Code 99
SOURCE: Error 99 Canon 30D
I also had this problem.
Try to remove the battery for more than 1 minute.
Also try to remove the CF-Card for more than 1 minute.
For me this only resolved the problem for 5-10 pictures.
Then I had to remove battery and CF-Card again.
The only real solution for this problem is to give the lens to repair.
Because this problem is caused by a wrong adjustment of the lens aperture.
SOURCE: Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
SOURCE: Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
SOURCE: shutter sticking open
Hey jimicricket,
The mirror is what reflects what the lens is seeing up to the viewfinder, and if it is sticking in the up position that is why you can't see anything sometimes thru the viewfinder. I would have the camera looked at by an authorized service technician, and it's possible that it just needs a good cleaning.
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Cannon 35mm EOS Rebel X S Shutter Problem
problem in shutter clean the shutter with white petrol dry it no need of lubrecant
