I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced. Regards,Richard
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at [email protected]. I think DACOR products are overpriced and junk.
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months). Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
