20 Most Recent
Dacor ECS227 Epicure Electric Double Oven Questions & Answers
Dacor model W305 oven element will not turn off
If the element in your Dacor W305 oven will not turn off, there are a few things you can try:
- Turn off the power to the oven by unplugging it or switching off the circuit breaker. Wait a few minutes and then turn the power back on to see if the element has reset.
- Check the oven's temperature sensor. If the sensor is faulty, it may be sending the wrong signal to the oven's control board, which can cause the element to stay on. You can test the sensor with a multimeter to see if it's functioning properly.
- Check the oven's control board. If the control board is faulty, it may be sending a continuous signal to the element to stay on. You may need to replace the control board if this is the case.
- If the element is physically damaged, it may be causing a short circuit that keeps it on. In this case, you will need to replace the element.
If none of these solutions work, it may be best to contact a professional technician to diagnose and repair the issue.
2/27/2023 5:33:55 PM •
Dacor Ovens
Answered
on Feb 27, 2023
Have Dacor wall oven ECS130SBK . The time is correct but to the right it says OFF in red. How do I fix it?
If your Dacor wall oven displays "OFF" in red, it means that the oven is not turned on or is in standby mode. To turn on the oven, follow these steps:
- Press the "Bake" or "Convection Bake" button.
- Use the "+" and "-" buttons to set the desired temperature.
- Press the "Start" button to begin preheating the oven.
If the oven still displays "OFF" after following these steps, try turning the power to the oven off for a few minutes and then turning it back on. If the issue persists, there may be a problem with the oven's control board or wiring and you may need to contact a qualified appliance repair technician for further assistance.
2/26/2023 10:36:24 AM •
Dacor Ovens
Answered
on Feb 26, 2023
Dacor up button not working
Try a spray of switch and contact cleaner spray with the power turned off. Get behind the buttons if possible.
1/17/2023 11:22:53 PM •
Dacor Ovens
Answered
on Jan 17, 2023
Dacor double oven model ECD227SCH relay board preventing oven from working......
It sounds like you may be having an issue with your Dacor double oven. If the relay board is preventing the oven from working, there could be a problem with the board itself or with a component it controls.
To troubleshoot this issue, you may want to try the following steps:
- Check the oven's electrical connection and circuit breaker. Make sure the oven is properly plugged in and that the circuit breaker has not tripped.
- Check the relay board for any visible damage, such as burnt or melted components. If you find any damage, the board may need to be replaced.
- Check the oven's thermostat. It is possible that the thermostat may be faulty and not allowing the oven to heat up.
- Check the heating element. If the element is not heating up, it may need to be replaced.
If these steps do not help resolve the issue, you may need to call a repair technician to diagnose and fix the problem. It is generally not recommended to try to repair an oven yourself, as it can be dangerous and may void the manufacturer's warranty.
1/6/2023 8:10:17 PM •
Dacor Ovens
Answered
on Jan 06, 2023
Dacor ecs230sch top oven not working
old post, but this video should help find the reset able thermal fuse
http://blog.applianceboards.com/installs/resettable-thermal-fuse-on-dacor-ovens/
10/28/2021 6:22:27 AM •
Dacor Ovens
Answered
on Oct 28, 2021
