Have a 1970's elna su supermatic with lots of cams but can't get them to work properly
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
PLACE WHERE YOU CAN BUY PARTS MACHINE ELNA SUPERMATIC
I don't think you can do reverse with the cams!
I have a similar problem with my Elna su (1970's). Except only the forward part of the cam stitch works. The part of the cam stitch that requires the machine to reverse stitch doesn't work. It just keeps doing the forward part.
But the machine will reverse stitch when I'm not using a cam dics.
Any ideas would be great!
Thanks.
foot control
