20 Most Recent Elna Heirloom Edition 6005 Questions & Answers
2answers
What is current monetary value of this machine
try http://sewvacdoctor.com/ for an appraisal or you could search EBay for something similar being sold as an indication. Looks like its a fairly new model so if its had very little use and is say 1-2 years old, perhaps 1/3 of new price??
10/29/2022 5:40:42 AM • Elna Heirloom... • Answered on Oct 29, 2022
Needle threader
www.sewingpartsonline.com has your part # 734515009, it is kind of pricey at $12.99 but it is worth having the correct part. This company is wonderful for parts and very quick service. You will like them.
9/21/2017 11:19:11 PM • Elna Heirloom... • Answered on Sep 21, 2017
How to adjust bobbin tension on 6005 elna sewing machine?
Apparently this Elna model has automatic tension settings. May be something you need to have a professional technician address. ...
2/15/2016 6:10:09 PM • Elna Heirloom... • Answered on Feb 15, 2016
How do I oil my sewing machine?
Consult your owner's manual in the maintenance section. Your machine is computerized and as such probably requires little oiling, possibly none. Do NOT oil unless you follow the manufacturer's instructions and use only oil that the manufacturer recommends. You can order an owner's manual here, or contact your Elna dealer/web site: http://www.sewingpartsonline.com/elna-sewing-machine-instruction-manuals.aspx?gclid=COzSrceIrscCFchlfgod7rQM5A http://www.ps2netdrivers.net/heirloom.edition/elna.6005/...
8/16/2015 4:58:36 PM • Elna Heirloom... • Answered on Aug 16, 2015
The needle thread won't connect with the bobbin thread to make a seam
it will be one of a couple of things, easiest to fix would be needle in backwards, not fully into the needle holder, or wrong gauge needle for the machine. Or harder to fix, the timing is out. If you have hit something hard while stitching or broken a needle you could have knocked out the timing. Not so easy to fix yourself and best taken to a sewing machine mechanic if you suspect this is the problem.
7/19/2015 6:20:42 AM • Elna Heirloom... • Answered on Jul 19, 2015
Computer won't clear "bobbin winding" even though bobbin threader is disengaged to the left
could be a computer problem,, try turning the machine off and on again and see if the computer clears it, and if not the computer may need to be checked
6/5/2015 2:14:28 PM • Elna Heirloom... • Answered on Jun 05, 2015
HOW DO I GATHER FABRIC?
12/3/2014 8:18:25 PM • Elna Heirloom... • Answered on Dec 03, 2014
Inserting needle into elna automatic
On my Elna SU the flat side goes to the rear
11/14/2014 2:59:09 PM • Elna Heirloom... • Answered on Nov 14, 2014
My Elna 6005 just stopped everything went blank no power no lights no nothing what could be wrong?
No, should not have a fuse. Just plug in the cord carfully into the machine again. Make sure the wall socket has power first. Could be that the foot pedal is burned out if it has been used a lot. But that is not too likely. Moses
10/4/2014 3:08:51 PM • Elna Heirloom... • Answered on Oct 04, 2014
Timing is out on Elna su62 and will not pick up bobbin thread
The lower pinion gear is likely broken or cracked. Try this test. Unplug machine, turn hand wheel full rotation. The hook should also spin a full rotation. If it does not move or moves intermittently the gear needs replacement.
8/22/2014 7:24:03 PM • Elna Heirloom... • Answered on Aug 22, 2014
What does the error #1 message mean on the display?
troubleshooting guide in manual usually lists this info.
8/15/2014 12:03:13 PM • Elna Heirloom... • Answered on Aug 15, 2014
How do I lower the feed dog
I think the leaver to drop the feed dogs is in the back.
7/16/2014 9:40:23 PM • Elna Heirloom... • Answered on Jul 16, 2014
0answers
Sewing Machines Logo
130 questions posted
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Elna Sewing Machines
Most Popular Question
gather fabric
  • Sewing Machines
