SOURCE: I turned the switch to the
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
A quick chck is to remove the drive and connect it direct to aPC with a suitable interface eg SATA or IDE.
If you can now see and use the drive it is the enclosure
Anything else and the drive may be dead
SOURCE: Retrieving files from external hard drive
Try using the file settings and transfer wizard, to transfer from one hdd to the other.
SOURCE: External Harddrive does not work
Hi:
Hitachi hard drive are junk they are poorly made, but here is an option the could by a bigger hard drive and install it in the External case they are all the same, first take out the old HD from the case and take it with you to the store and purchse the same connection type wether its IDE or Sata and install it in the case, the cases are universal and all most all 5-1/4 inch HD will fit in the case is does not have to be A Hitachi Brand any brand will fit, I recommend a Seagate HD.
