I'm looking for A Windows XP Ethernet Controller driver that's compatible with the Dell Studio XPS 435 MT.
SOURCE: Missing Drives for Dell Optiplex GX260 PC Desktop Problem
if you don't have the cd with the drivers and utilities, then you can download the drivers online with another computer. (you will need a thumb drive or cd to save it on) you will also need to make sure you know what brand of ethernet card your computer came with. once you get that ethernet card working, you can get online and download the remaining drivers, possibly through windows update. be sure to select custom update, not express, so it will search for the hardware drivers for you.
SOURCE: ethernet driver for dell dimension 4600
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
SOURCE: DELL Dimension 2350
I wanted to use the advice by Daniel and it did not work for the Ethernet Driver. My dowload which worked, was R64645.exe and is described here
SOURCE: no ethernet controller in device manager
You need to flash the cmos.. To do this open it up and look for a switch inside the system., press for 5 seconds and release.
If you cant find the switch or there isnt one, then locate the battery on the board (its a big watch battery) pry it off, hold the power button down for 1 minute, the press it 5 times, replace the battery.
NB: UNPLUG THE SYSTEM BEFORE ATTEMPTING THE ABOVE. Once this is done follow the onscreen instructions to enter the bios or setup, load optimised defaults then save and exit. Your device will now show up in the device manager.
