I've selected the appropriate size
SOURCE: I'm trying to scan in a document and then fax it using HP Photosm
Unlike most scanners, you must put the page that you want to copy in lower right corner of the glass (notice the small arrow pointing to the corner). This should fix any problem with an image being cut off. As far as faxing, I don't think the C3180 is able to fax pages. Hope this helps
SOURCE: I have a printer software problem.
Have you run the check to make sure you have the latest drivers option on the HP website. You can also download the compatible version of the HP Solution Center from the same site.
Let me know if this helps you solve this problem. Thanks.
HP Site is
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1141647
SOURCE: when i scan an 8.5x11 document from my hp 6210 to
uninstall ur printer support driver and install it again. and select default setting for your printer
SOURCE: When using scan feature in my HP 7680 printer any
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
check paper loading area and printing area is there any paper jammed? remove any viable objects, If printer in warranty surrender to HP. check paper path sensor...
