Water leaks onto floor of passenger side front. have gone all over the windscreen with silicone and taped up the vent inlets without success. Seems to leak when driving and not when sitting still in heavy rain.
It is probably coming in through the firewall some where after being splashed up by the wheels check behind and above the left front wheel for holes
SOURCE: rain water leak
http://www.dodgedakotas.com/boards/dea/524.html
DodgeDakotas dot com has a lot of postngs about water under the Dakota's passenger side carpeting. My own 2005 is leaking, too. Main culprits to check: AC drain tube @ firewall (I think that some Dakotas had to have a 90-degree tube added to the outside end so that water wouldn't blow back into the cab. Great desing, Dodge. Rear window seal; Along the right-side window/roof pillar; the gromment in the passenger side door for a wire pathway. Sounds like some get this fixed under warranty - others meet w. resistance. Good Luck!
SOURCE: Front passenger side carpet getting wet
The AC evaporator units have a drain hose that runs through the floor because condensed moisture is a fact of life with AC units. Yours is plugged. You will have to get under the vehicle and look for the hose where it comes out, then take like coat hanger wire and clean it out, It is somewhere in the vicinity of where the passenger foot well meets the fire wall. If you have to raise the vehicle to get under it, make certain you have it safely supported. If you don't have the stuff, drive the passenger side wheels up on a good curb and use some cardboard to slide under.
SOURCE: water leak
Water leak test the windshield . Carpet should be removed and dried out, Replace matting if necessary, because it will NEVER dry. Look by front firewall floor for drippage. Windshield moldings must be removed if resealing is nec, and be sure to use a neoprene water resistant windshield sealer. Hope this helps.
SOURCE: water sloshing around in the vent, leaking onto passenge floor.
There should also be a drain tube or hole below duct work on outside of firewall or maybe even lower.
SOURCE: 2000 Ford Taurus: With heavy rain, water leaks
if you can remove the plastic "cowl" section(s) at the base of the windshield and clear out any debris.sticks,dirt,acorns,mud,etc. THEN run a garden hose where the rain normally would run down and "flush"the drainage paths at each end by each fender. see if that fixes the problem. theres also a possibility that the windshield seal could be bad.
