Chef's Choice 677 Cordless Electric Kettle Logo
Ogost Posted on Apr 06, 2013
The pot turn on the light but dosent heat the watter
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
996
Points
My kettle light goes on but water will not heat .
A GR 10-4 date code 07-04-005 When I put the 2nd pot of watter in and let run down into the tank, it leaks watter form the top out the bottom.
I had the same problem. On mine (and probably yours) the problem was the seal between the (upper) plastic water reservoir and the lower (metal) heating reservoir. No replacement seal is available.
I fixed mine by coating both sides of the old seal with aquarium grade clear silicone sealer - available at pet supply stores. Just a light (1/16") coating is all that's required. Carefully re-assemble and allow the sealer to cure for 24 hours.
I did that over a year ago, and it hasn't leaked a drop ever since.
Check engine light on. Took for service and
The check engine light can come on if there is watter in the fuel add some injector cleaner to a 1/2 tank of gas this will dry the watter in the tank
I cannot brew one pot after another. It seems that the heating element will not cool off so it will not trigger the fresh pot to brew.
Do you turn off the pot before you refill the reservoir to brew the second pot? The heating element should not have anything to do with triggering the second pot. Turn off the coffee maker, change/refill the coffee, refill the reservoir and turn the pot back on. This works on my Cuisinart.
Dryer tumbles but won't heat.
It looks like the heater is gone (the main reason for there breaking is watter stone), this will cost you betwen 20 and 40 $ (heater is only about 4-5 $ but the handy man is expansive )
Or your machine uses hot watter as a input (not regular cold wather) i've seen couple of those
I was using the iron and then there was no heat even thought it was still plugged in--the light on the iron went out while still plugged in
there are 2 possibilities what could be wrong
First one is that you didn't use distilled watter (you could use regular) by doing so a small coat of watter stone is covering all internal parts
Mix some vinegar with watter (ration 5 watter 1 vineger) and putt it in iron and than it will start breaking watter stone, you should use some cloaf that u don't need to wipe off exces watter stone, don't get burned!
DO NOT IRON WHILE DONG THIS
Second one is that there is a cable problem, but this is a big problem...
Hair straighner .
Does not seam to "light up" ?
Light goes on ??
Not heating - but the light on ??
If so - the heating element has failed..
Time for a new one I am afraid ;o(
1helpful
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
1helpful
3answers
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Top Chef's Choice Kitchen Appliances - Others Experts
john h
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
