20 Most Recent
Chef's Choice 677 Cordless Electric Kettle Questions & Answers
Kettle does not automatically shut off
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on
electric kettle review sites.
Stopped Working!
Have had same problem several times. My fix was to remove the five screws on the underside of the pot and lube all the plastic linkage with WD-40. Apparently the linkage gets a bit warped with heat. The pot lasted about five years and today the switch contacts melted inside. I doubt that parts are available, so...
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Chefs choice electric kettle 677 works sometimes
I have the same problem and I tried to open the base to clean the contact points but found that it is molded into one piece and would have to be cut open and then glued shut when finished. I am about to pull out the file for the kettle contacts because its headed for landfill If I do nothing so I cant make it worse. I am going to file the contacts until itere a little shiny.
