1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
97 chevy tahoe wont start from the key but will start from the starter
Wont start from the key but will start from the start
Kardoc
Level 3:
Top Expert:
  • Chevrolet Master 7,503 Answers
  • Posted on Nov 02, 2013
Kardoc
Chevrolet Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2760452
Points
58323
Check the neutral safety switch. Also some GM have a starter relay in the fuse box. Also you could have a bad ign switch
1 Related Answer
Anonymous
  • 306 Answers
  • Posted on Feb 13, 2010
SOURCE: my 97 chevy tahoe is really hard to start in the
you may want to have a load test done on the battery. this can be done at any autoparts store and the test is usually free
2answers
1997 chevy tahoe wont start
could be fuel pump or even crank or cam , timing sensor. Did it start running strange before this?
2005 chevy tahoe wont start
One of two things is possibly wrong, the starter solenoid is bad or the starter has failed. Sounds like you battery is fine.
2002 Chevy Tahoe. Car wont Start, Starter will keep on trying to start even with key out.
I'd look at the starter solenoid. It also contains the switch contacts that actually connects the battery to the motor. It may be starting to stick.
1helpful
97 Chevy Tahoe has spark and gas but wont start. I was driving came to a light and it shut offf. I replaced the fuel filter yesterday Ans the fuel pump was replaced April 2012 it only start when you add...
I had same problem on my 97 tahoe shut off while driving and wouldnt start only turned over. checked everything and when i replaced ignition module started right up no problem. Hope this helped and saved ya money
97 chevy tahoe truck wont start from the key
The ignition switch is probably bad and not letting the fire get to the starter from the key. I say this because you are getting fire at the starter or you would not be able to short it across the solenoid. Hope this helps.
13helpful
2answers
My 96 Chevy tahoe 5.7L vortec wont start
does your instrument panel turn on when u turn the key to the on position?
My 97 chevy tahoe is really hard to start in the am when its cold out can somebody help me
2answers
My 1997 chevy tahoe does not start right away.
Sounds like a starter problem, suggest you get it checked at your local trusted mechanic the next time it starts... If the starter is your problem it wont start for many more times.
'96 Chevy Tahoe won't start
it sound like its in the coleum . may be your key switch is bad . its something simpull. check your fues inside and out .and see if you can hear your realay working. i hope you can find the prob
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
