20 Most Recent
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Questions & Answers
WEAK SPARK AT PLUGS
That truck should have no points. It should have electronic ignition. Sounds like bad wires or bad coil(s).
Gear indicator
When you move the gear selector and the shift indicator does not move, there is a problem with the indicator. Misalignment could be a reason that can be solved with an adjustment by a trained mechanic or there may be a more serious problem.....For more info-https://www.usedengines.us/blog.php
1997 chevy truck 1500 neutral safety switch doesn't work
If you follow the steering column down the sw. is a half moon shaped sw inside attached to the column. Remove the wiring clip and the two screws and put on the new sw. be sure the truck is in park or set the new sw. to the position it is in now. Better to have it in park.
What size bolts do I use for the undercarriage?
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
I have a 1997 chevy c 1500 it starts and dies in 7 seconds what could the problem be
You may have a spark problem. Hook up a remote spark tester and locate it where you can watch it . Watch to see if there is a lack of spark when the engine dies. Also hook up a remote fuel pressure tester and see what your fuel pressure is when the engine dies. If you lose spare I would look at the module in the distributor as the problem. If it fuel, it could be a weak pump or a restricted fuel line. Also , find someone with a scanner and have him read the codes. It could be that simple.
95 z71 new fuel pump no fuel to injectors an no
The injectors must receive a signal from the ECM to fire. What is your fuel pressure. 60-65? Check the injectors wires to make sure they get current to fire. Possible blown ignition fuse. Red 10 amp fuse in fuse panel.
1997 chevy 1500 cheyenne Manual Transmission
Check the fluid in the clutch master cylinder. It may be low. You may need to bled the system or replace the slave cylinder. If both of these are on, you may have a clutch problem.
Why does my 1997 chevrolet
It could have bad wires, wires that were crossed during a tune-up, low fuel pressure, bad intake valve, slow timing, too lean of fuel/air mixture,worn cam shaft bad injectors
1995 V8 350 CI CHEVY 1500 WONT STAY RUNNING
Possible a very bad vacuum leak. Also could be bad fuel. there again maybe that your plugs are worn of your fuel filter is dirty. Could also be that your ect sensor is bad. A few of the things for you to look at.
