After playing for 20 minutes on medium volume, unit when completely out.
SOURCE: Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
SOURCE: unit shut off after 15-20 minutes
The problem is IC 451, (Yamaha Part # XU814A00) (Number on part PQ05RD11 Made by Sharp). It's a + 5V 1A Voltage Regulator.
It's located at the bottom of the power supply board mounted to the front heat sink. It's a four legged TO220 Package outline. So don't try to slip a three legged 5 volt regulator in it's place. This can cause serious damage and headaches. Change this part and everything should be good.
SOURCE: Can't find Yamaha RX-V363 code for a Time Warner
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V363_U.pdf
Here's your manual. Hope this helps
