Intel D865GBF Motherboard Logo
Moshe Gershon Israeli Posted on Mar 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Short circus in mother board
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Intel Master 2,226 Answers
  • Posted on May 25, 2014
James Miller
Intel Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447573
Points
2985
Need new mother board for flytech bladestar
it may be that your contoler got wet or spilled on or mother board had a short on it see woowee .corp
Samsaung z400 short mother board please help you
1helpful
Tv fell off the stand onto a carpet floor now wont turn on
Possible that the fall has damaged the mother board and so there can be CRACK ON THE MOTHER BOARD. So you need to remove power cord and check using a good inspection lamp on the board for broken circuit board. Use a good soldering iron with wire strips to join - take care not to short circuits as each line must be tested for short and continuity.
A beep noice error E01
If there are one or more short beeps without any error, then it is common.
If there is an error with one long or short beep sound, then it is regarding the System board (Mother board).
Sollution: Check to see that all adapters, memory modules and chips are seated firmly; check for proper power connections to the Mother Board.
10helpful
2answers
2helpful
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
1helpful
Mother board short shurcute
nokia72 mather board short shurcute please halp me.
Mother baord beep sounds
Which model? Are the beeps 1 long, 2 short, 1 short, or just continuously short? Continuously = RAM needs checked and/or replaced (you can download either Memtest or the Microsoft Memory Diagnostics CD's to check it) 1 long and 2 short or 1 long, 3 short = VGA card needs checked
1helpful
Pentium 4
the motherboard and the power box should be replaced. you hade a short and the power box went out and the mother board shorted out as well. If you replace the mother board you will see. This happens alot to people. Check out the numbers on the board at type it in the web and find out what kind you have. you can find motherboards cheap on ebay.
2answers
Short circuit in vcc and ground
Some questions first: Is this the same board mentioned in your other post? If so how did you decide that you have a short on your motherboard?
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
