Dishwashers Logo
Lory McCoy Posted on Mar 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
  • Anonymous Mar 28, 2014
    has
Sal De
Level 3:
  • Dishwashers Master 2,699 Answers
  • Posted on Feb 25, 2018
Sal  De
Dishwashers Master
Level 3:
Answers
2699
Questions
0
Helped
1003337
Points
8029
The flashing light is an error code,you either have a bad heater or the board is bad,once you reset it after like 6 or 7 wash loads it will start over again,if you remove the bottom kick panel,you'll find the tech sheet there,look up light flashes 7 times and it will tell you how to check the heater from the board to see if the heater or board is bad
  • Sal De Feb 25, 2018
    this error is telling you that there's a heat problem
Anonymous
Level 3:
  • Dishwashers Master 1,010 Answers
  • Posted on Mar 21, 2013
Anonymous
Dishwashers Master
Level 3:
Answers
1010
Questions
Helped
247246
Points
3078
Check, if you have water in the machine, if yes, your control board could at fault
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Jan 09, 2009
SOURCE: Whirlpool dishwasher clean light flashing
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Anonymous
  • 188 Answers
  • Posted on Feb 20, 2009
SOURCE: whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Anonymous
  • 188 Answers
SOURCE: clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Anonymous
  • 188 Answers
  • Posted on Apr 03, 2009
SOURCE: whirlpool gold dishwasher will not work the clean
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Anonymous
  • Posted on Apr 14, 2009
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 • Dishwashers
4helpful
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
41helpful
My dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
The dishwasher won't start, the clean light flashes green 7 times
7helpful
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
1helpful
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
