Live in a condo with an electric fireplace. It has started to make a lot of noise when I turn it on. I have no idea what brand it is but it is only about 4 or 5 years old. Would I call an electrician for repairs or would I need a fireplace specialist?
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
SOURCE: Fireplace Fan Replacement
Well a blower replacement requires some knowledge of electricals. i have found a manual showing the blower replacement. Its not the same model as yours but i think it will be helpful.
12.153.20.72/tech/manuals/108321-01A.pdf
SOURCE: Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
SOURCE: Electric Fireplace Insert
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: My Heater stopped working on my HEF33 Electric fireplace
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
It's weird that your fireplace is making noises when it's only five years old. Mine is at least a decade old, and the fan is so loud that it's difficult to hear people speak in the same room when it's on. I think I'm going to be safe and fall a fireplace repair service instead of an electrician because they'll probably know the problem better. http://www.aoneheatingandairmd.com/heati...
