There is water under the crisper drawer that is eventually leaking our of the refrigerator. It appears to come from the freezer area but I am not sure of that. It sometimes accumulates on the lower shelf behind the crisper drawer and freezes.
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
I understand that the reason there is water is because the drain is clogged. What I can't figure out is how do I get to the drain and the hose on my particular refrigerator. I posted the maker and model number but received information for other makers refrigerators. It seems each one is different. So I would appreciate any suggestions for a Magic Chef model # CTN1511AEW. Thanks everyone for all your help! Lola
SOURCE: water collects in bottom of refrigerator
This is something you will be able to solve, the like below will take you to a detailed instructions and photos of what to do. Let me know if you need more help, Thanks Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
SOURCE: water drips from freezer into refrigerator
The drain is clogged..you need to see if it has a rubber drain trap going into the back side of refrigerator. if so, twist and turn as you pull it out and clean it..replace and then check that drain is open..if no drain trap on back side of refrig..remove freezer wall and open drain from inside freezer..you need to clean out drain trough using hot water..a little messy,but effective
SOURCE: Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
