Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
Posted on Feb 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i logg on my buddies wont show!
Ok so when i log on to ichat it says connecting and then non of my buddies come up and it connects again and again and then it says you have logged on to many time please try again in a few minutes can someone please help me !
winserp
Level 3:
Master:
  • Master 363 Answers
  • Posted on Oct 18, 2016
winserp
Master
Level 3:
Master:
Answers
363
Questions
0
Helped
207555
Points
1105
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Feb 25, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
7980
Points
53
You just go to-> ichat->buddies->new instant message-> friends mail id-> then its done
How do I unmute during ichat on my mac book pro
In iChat 4 and upwards the Video and Audio streams are on the same port.
This would make it virtually impossible to block one without blocking the other.
Just to double check
System Preferences > Sound > Input
Ideally this should have the Mic chosen and the volume set to make the blue bar get to at least 1/2 way (3/4s is better). It should not move so far that it bangs into the right hand end.
This will cause the OS software to "Clip" the Audio to prevent feedback - which means no input is made and you will hear nothing.
Next.
iChat > Preferences > Video section.
If there are two Inputs showing in System Preferences he will have a drop down
It should list the same device.
The green bar below the Video pic should also move (Although less than the blue bar did/does)
Headsets
If he is now using a Headset.
Change the iChat Option to anything but the headset mic.
Do the same in System Preferences > Sound > Input.
Now set System Preferences > Sound > Input "First"
And iChat > Microphone Drop Down "Last"
He may need to do this for an Output choice if it appears in iChat and in the System Preferences > Sound > Output.
He needs to be concerned with with getting Sound In to iChat as that is what you hear.
It is easy to think that it is Output as it goes over the internet to the Buddy.
More.
The Video Menu of iChat
In here the Microphone Enabled should be ticked
Selecting this items toggles the tick on or Off (And the Mic On or Off)
I would also check the View Menu
In here make sure the Show Audio Status is ticked.
This will show Audio icons next to the Buddies (Particularly if you deselect Show Video Status)
Show Video should allow Audio but it will not hurt to check.
In fact I would toggle the Microphone Enabled and both Show Statuses to make the App write the info to the .plist
Then try an Audio Only chat
You can do this from the Buddies menu (Or right clicking a Buddy) or by having Show Video Status Off.
Yet more.
I would also open the Connection Doctor from the Video menu at both ends during a chat
This will report the stats.
If his Bitrate is not stable then his audio may be effected.
iChat will try to cope with changes by Buffering the Video which means dropping frames which then means the audio is dropped as it will not be in sync.
You can try Limiting his Bandwidth in the Video Section of the Preferences to 500kbps
This will smooth out large variances when using Extremely fast services that vary.
500kbps is more than enough for a 4 way Video chat as Host but is a useful tool in iChat 5
If his Framerate also varies it will be a sure sign that his Internet speed is varying.
It may pay for you to drop your to 500kbps as well as hs end may be struggling to deal with high data loads from your end.
As a Last resort try both end at 200kbps (Anything below this will not Video)
Change one end at a time and keep an eye on the Connection Doctor to see when the end that has changed has settled. The Buffering will smooth out the change.
My yahoo messenger will not let me logg on cause it says im logged in somewhere else. how do i fix this problem?
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
1helpful
My ichat buddy list doesnt show up
my buddy list is not showing when i sign on for aol please help me set up my buddy list thanks
I can see my buddy, who has a mac, but he can't see me with my pc. We are trying to connect using ichat. We were able to connect one time, but not again.
http://forums.pcworld.co.nz/showthread.php?t=86311
I would probably try using pidgin
I really like it and it's super easy to use.
Can only connect to yahoo messenger no other messengers on mac
search msn messenger for mac in googl.com
also a ichat as well
download them
after it connect porperly
Not all buddies from all groups appearing in my AIM list
The AIM client for RIM is limited to 30 contacts at this point, so it won't show everyone. They are in the process of updating their client so that it shows ALL buddies.
What you could do is use an instant messaging client called BeeJiveIM, which is a multi-protocol instant messaging client that allows you to connect to AIM, Google Talk, Windows Live, Yahoo!, MySpace and ICQ. There is a 30-day free trial at http://www.beejive.com.
Connecting to Ichat
Please click on this link you will find exactly what you need to do exactly(with pictures) ,,
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/iChat.htm
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
