I have a dial tone it dials the number then acts like it is going through and then a recording comes on and says if you would like to place a call hang up... I have a hp 640 fax thanks lynn
Once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode. If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection. Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
