SOURCE: Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
SOURCE: I need to get a meter reading.
Hello sir; You just press "user mode' it will show up "total count"
SOURCE: Lanier LD135. How do I program it to print
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
SOURCE: Got a function code SC322 on lanier 5622 copier.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
