Seagate ide drive, I have a dvd/cd drive, 3 sata drives and 2 pata drives. The 5th drive does not show in bios. Have changed cables, drive order, jumpers- m/s and cable select, did drive tests= all fine. If I turn the 5th drive on I loose both 4th and 5th drive. If I turn off 5th I get 4th drive(master) back. What else can be done? this model can support 6 drives (0-5) 4 satas and 2 patas (my dvd/cd drive is a sata). bios setting for drives = sata operation is (RAID Autodetect / ATA). Tried factory default settings but no results. Any suggestions appreciated for multiboot system with windows xp pro and linux os's. This bios is severely limited for multiboot system by having only one boot priority drive for a sata drive or pata drive (depending on device priority set in bios). What else can be done?
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
SOURCE: Dimension 3100 Won't Boot
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
SOURCE: Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
