SOURCE: I need owner's manual for proform 900 cardio cross trainer
go to www.iconfitness.com and follow the instructions. You can do everything from that site. We are service dealer for them, and we like to help..
SOURCE: Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
SOURCE: I have a Free Spirit
I have the same machine. There are 4 D cell batteries in a small drawer at the bottom of the console. The screw is located on the left hand side and is a bit awkward to get at. The drawer slides down from the middle of the console.
SOURCE: belt off of pro form 700 cardio cross trainer
Dear Sir:
Hello , I hope everything is fine.
Please do the following:
o 1
Remove the key from the machine and unplug the unit for safety
purposes.
o 2
Adjust the rear roller adjustment bolts using an allen wrench. The right
bolt should be turned one-fourth turn clockwise and the left bolt should
be turned one-fourth turn counterclockwise.
o 3
Place the key back into the unit and plug it back into its power source.
o 4
Run the Proform treadmill for five minutes to make sure that the walking
belt has fully recentered itself.
o 5
Repeat these steps if necessary.
If the Belt Slip when in use:
o 1
Unplug the unit and remove the key card.
o 2
Tighten the walking belt by turning both rear adjustment bolts clockwise
using an Allen wrench.
o 3
Replug the unit and reinsert the key card.
Thank you in advance, sincerely. Blessing.
E.CUADRA
Managua, Nicaragua. c.a.
SOURCE: What's your problem? I need an instruction
GO TO THEX 2 OPTIONS:
1) IS FREE: HTTP://FITNESS.MANUALSONLINE.COM
2) YOU MUST PAY: WWW.FITNESSREPAIRPARTS.COM
SINCERELY.
E.CUADRA
MANAGUA, NICARAGUA. C.A
