HEWLETT-PACKARD Hewlett Packard P1102 Laser Printer Logo
A
Anonymous Posted on Feb 27, 2013
How to print configuration page of HP LaserJet P1102 ?
1 Related Answer
Anonymous
  • 154 Answers
  • Posted on Oct 03, 2012
SOURCE: how to self test page of HP laserjet P1102?
Press and hold the red X button (cancel) until the green light starts to blink.
tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
2answers
My HP P1102 will not print labels
Go to www.hp.com/support and let the site auto detect your printer and download the driver automatically
How to print P1102 test print
That machine doesn't have a control panel but you can test it by printing out the configuration page
At the control panel, press and hold the cancel button until the ready light starts blinking, and
then release the button.
How to print meter reading from hp laserjet pro400
Configuration page denotes total gape count..
Press menu button...scroll to information..enter...scroll to configuration page...enter..
How to print wirelessly from iphone on hp laserjet p1102
Here's a solution HP has that explains how to print wirelessly from iPhone for that printer. Review the different options and find the solution that works best for you.
HP Printers and Supported Mobile Printing Solutions
I am an HP employee.
Hp laserjet p1505 how to print configuration page ?
Go into the Printing Preferences and Click Services. It should come up to a page that says Print Information Pages. Drop the arrow down to configuration page. It's the second Drop Down Arrow
How to self test page of HP laserjet P1102?
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Obehiaghe Adoghe
Obehiaghe Adoghe
ADMIN Eric
ADMIN Eric
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
